The hb_verifier Tool
The hb_verifier is a consistency verification tool that supports performing cosine similarity comparisons between ONNX models, between ONNX model and HBIR model, between HBIR model and HBIR model, and output consistency comparisons between HBIR model and HBM model.
The cosine similarity indicates the consistency between quantized models at different stages. As the cosine similarity gets closer to 1, it indicates that the outputs of the two quantized models being compared are closer to each other.
Consistency comparison prints output consistency information for the comparison models, including output name, consistency, number of inconsistent elements, maximum absolute error, and maximum relative error.
Support Range
  • Fbc represents the floating-point HBIR model, which refers to the HBIR model before convert exported after the model conversion by PTQ API method or QAT pipeline.
  • Qbc represents the fixed-point HBIR model.
Comparison ModelsComparison ScenariosWhether the Model is from hb_compileInput Data Requirement
Onnx vs OnnxCosine similarity comparisonNot interestedOne original data
Onnx vs FbcCosine similarity comparisonNoTwo sets of data corresponding to the Onnx and Fbc models
Onnx vs Qbc
Cosine similarity comparisonYes
One original data
Onnx vs QbcCosine similarity comparisonNoOne original data
One runtime data
Fbc vs QbcCosine similarity comparisonNo
One original data
One runtime data
Qbc vs HbmOutput consistency comparisonYesOne runtime data
Qbc vs HbmOutput consistency comparisonNoOne runtime data
Hbm vs HbmOutput consistency comparisonNot interestedOne runtime data
Attention
  1. For Fbc (floating-point HBIR model), if some preprocessing nodes have been inserted, the raw data needs to be modified to match the model inputs.
  2. Currently, the hb_verifier tool does not support the cosine similarity comparison for the ptq_model.onnx model generated during the model quantization and compilation process when separate_batch or separate_name has been specified.
  3. Currently, the hb_verifier tool does not support the output consistency comparison for hbm model generated after enabling data storage L2M by specifying the max_l2m_size during model quantization compilation.
  4. All models involved in the comparison must be the outputs of conversion and compilation from the same pipeline(PTQ/QAT).
Usage
Usage: hb_verifier [OPTIONS] Options: -h, --help Show this message and exit. --version Show the version and exit. -m, --model TEXT The types of parameters supported include onnx/bc/hbm models, comma-separated. [required] -i, --input TEXT Original model input files. [required] -c, --compare_digits INTEGER The number of decimal places to compare. --ip TEXT Board ip (comma-separated, number should match HBM model count). -u, --username TEXT Board username (comma-separated, number should match HBM model count). -p, --password TEXT Board password (comma-separated, number should match HBM model count). --port TEXT Board ssh port (comma-separated, number should match HBM model count).
Parameters Introduction
Parameter NameParameter Description
-h, --helpDisplay help information and exit.
--versionDisplay version information and exit.
-m, --model
Specify the model input, supports ONNX model (*.onnx), HBIR model (*.bc) file, HBM model (*.hbm) file.
The two model addresses are separated by a “,”: -m model1,model2.
-i, --inputSpecify the data to be used for inference testing; only *.npy files are supported.
For multi-input models, there are two ways to pass input data, separated by commas:
  • input_name1:input_data_1.npy,input_name2:input_data_2.npy, …
  • input_data_1.npy,input_data_2.npy…
If you need to input data for two different models, please use two -i parameters.
Attention:
  • The input data must include preprocessing operations, such as color conversion, mean, scale, etc., which should be done externally when preparing the input.
  • If there are no special requirements, the raw data can use the calibration dataset as input; runtime data needs to be consistent with the input of the quantized model.
  • The order of input data names must match the actual input order of the model.
-c, --compare_digitsSet the numerical precision of the comparison inference result (i.e. the number of decimal places to compare the value), if not specified, the tool will compare to five decimal places by default.
--ipSet the IP address of the development board, default is empty. Multiple entries need to be separated by commas.
-u, --usenameSet the board SSH user name, defaults to root. Multiple entries need to be separated by commas.
-p, --passwordSet the board SSH password, default is empty. Multiple entries need to be separated by commas.
--portSet the board SSH port, default is 22. Multiple inputs need to be separated by commas.
Usage Examples
Cosine Similarity Comparisons
ONNX Model and ONNX Model
Cosine similarity comparisons were performed between the ONNX model and the ONNX model.
Take the model optimization stage model optimized_float_model.onnx and the model calibration stage model calibrated_model.onnx as an example:
hb_verifier -m googlenet_optimized_float_model.onnx,googlenet_calibrated_model.onnx \ -i input.npy
ONNX Model and HBIR Model
  1. Cosine similarity comparisons were performed between the ONNX model and the floating-point HBIR model.
    Take the model optimization stage model optimized_float_model.onnx and the floating-point HBIR model float_model.bc as an example:
    hb_verifier -m googlenet_optimized_float_model.onnx,googlenet_float_model.bc \ -i input1.npy,input2.npy
  2. Cosine similarity comparisons were performed between the ONNX model and the fixed-point model HBIR model.
    • If the model is compiled by hb_compile, take the model optimization stage model optimized_float_model.onnx and the model quantization stage fixed-point model quantized_model.bc as an example:
      hb_verifier -m googlenet_optimized_float_model.onnx,googlenet_quantized_model.bc \ -i input.npy
    • If the model is compiled by hb_compile and there are multiple input data, take the model optimization stage model optimized_float_model.onnx and the model quantization stage fixed-point model quantized_model.bc as an example:
      hb_verifier -m googlenet_optimized_float_model.onnx,googlenet_quantized_model.bc \ -i input1.npy,input2.npy
    • If the model is not compiled by hb_compile, take the original floating-model original_float_model.onnx and the fixed-point model quantized_model.bc as an example:
      hb_verifier -m googlenet_original_float_model.onnx,googlenet_quantized_model.bc \ -i input.npy \ -i runtime_input.npy
    • If the model is not compiled by hb_compile and there are multiple input data, take the original floating-model original_float_model.onnx and the fixed-point model quantized_model.bc as an example:
      hb_verifier -m googlenet_original_float_model.onnx,googlenet_quantized_model.bc \ -i input1.npy,input2.npy \ -i runtime_input1.npy,runtime_input2.npy
HBIR Model and HBIR Model
Cosine similarity comparisons were performed between the HBIR model and the HBIR model.
  • If the model is not compiled by hb_compile, take the floating-point model float_model.bc and the fixed-point model quantized_model.bc as an example:
    hb_verifier -m googlenet_float_model.bc,googlenet_quantized_model.bc \ -i input.npy \ -i runtime_input.npy
  • If the model is not compiled by hb_compile and there are multiple input data, take the floating-point model float_model.bc and the fixed-point model quantized_model.bc as an example:
    hb_verifier -m googlenet_float_model.bc,googlenet_quantized_model.bc \ -i input1.npy,input2.npy -i runtime_input1.npy,runtime_input2.npy
Output Consistency Comparisons
HBIR Model and HBM Model
Output consistency comparisons were performed between the HBIR model and the HBM model.
  • Take the model quantization stage fixed-point model quantized_model.bc and the model compilation stage model googlenet.hbm as an example:
    hb_verifier -m googlenet_quantized_model.bc,googlenet.hbm \ -i runtime_input.npy
  • Take the model quantization stage fixed-point model quantized_model.bc and the model compilation stage model googlenet.hbm as an example, and setting the ip to None indicates using the simulator:
    hb_verifier -m googlenet_quantized_model.bc,googlenet.hbm \ -i runtime_input.npy \ --ip None,10.10.10.10
HBM Model and HBM Model
Output consistency comparisons of HBM model across simulator and development board.
Take the model compilation stage model googlenet.hbm as an example. Setting the ip to None indicates using the simulator:
hb_verifier -m googlenet.hbm,googlenet.hbm \ -i runtime_input.npy \ --ip None,10.10.10.10
Output Contents
The cosine similarity information for the compared models will be printed within the terminal, as shown in the example below:
+-----------------------------------+----------------------------+-------------------+ | NodeName | TensorName | ConsineSimilarity | +-----------------------------------+----------------------------+-------------------+ | Conv_0 | 365 | 0.999978 | | Relu_2 | 367 | 0.999976 | | MaxPool_3 | 368 | 0.999901 | | Conv_4 | 369 | 0.999112 | | Relu_6 | 371 | 0.999212 | | ... | ... | ... | | Conv_189 | 554 | 0.984707 | | Relu_191 | 556 | 0.989554 | | Concat_192 | 557 | 0.989221 | | GlobalAveragePool_193 | 558 | 0.995896 | | Gemm_195 | transposed_replaced_output | 0.995836 | | Gemm_195_transpose_output_reshape | output | 0.995836 | +-----------------------------------+----------------------------+-------------------+
Among them:
  • NodeName represents the name of the operator.
  • TensorName represents the Tensor name of the first output of the operator.
  • ConsineSimilarity represents the calculated cosine similarity.
+------------+-------------+---------------------+--------------+--------------+ | OutputName | Consistency | Mismatched Elements | Max Abs Diff | Max Rel Diff | +------------+-------------+---------------------+--------------+--------------+ | output | True | 0/1000 (0.00%) | 0.0 | 0.0 | +------------+-------------+---------------------+--------------+--------------+
Among them:
  • OutputName represents the output name.
  • Consistency represents whether the output is consistent or not.
  • Mismatched Elements represents the number and percentage of inconsistent elements.
  • Max Abs Diff represents the maximum absolute error.
  • Max Rel Diff represents the maximum relative error.
